UrbanCobGirl
Hi Folks,
New poster here. Got my Chevy Express 3500 demo complete, now about to start the build. I've got a 10K GVWR on this. Totally stripped, it weighs abt. 8500 lbs., so I've got to stay under 1500 lbs for the build weight. I'll be living in the bus full time, so it will be my work/living space. I'm a woodworking artist, and all the equipment I'll have to have with me comes in just under 600 lbs., I need to do as lightweight a build as possible and also as sustainable as possible (yes I know - it's a diesel, but my footprint will still be considerably less than house living). So for flooring, I am considering a simple layer of R-10 Kingspan Greenguard rigid insulation directly on the floor with 3/4" plywood over that, which I intend to seal with AFM Safecoat, EXT Exterior Polyureseal. Since it's such a small vehicle, there will only be at most 8' x 3' of walking space, and I'll probably put a rug runner down over that as well. From what I've read, I can lay the rigid GreenGuard down with no adhesive and lay the plywood over and then build on top. I'd like to NOT put an adhesive down if possible, because if I want to change it down the line I don't want to have to go through what I did when removing all the adhesives that kept the rubber matting and rugs in place. And it'll be just me - not 16 kids in the bus. Has anyone in the forum done a*similar*flooring option? Any input and/or thoughts would be appreciated!
