Link to build thread in signature
RHOMBUS
Feb 22, 2015
217
South Dakota
I have seen other users have links to their build threads on here in their signatures, but when I try to use the BB code URL or THREAD, it says it is not allowed. I can understand not wanting external links to some degree, but linking to a thread here would seem to be mostly harmless. Mostly? :ermm:
I have a link in my signature. I do not think it is because you are not allowed but because you are not using the right format to post the link...maybe?
Do you remember how you did it, crazycal? Maybe when you first made the link it was allowed and now it's not? Could you copy and paste the code you used here?
it is in the user control panel, edit signature
make sure you're signed in, pick "user cp" at the top of the page
turf: I did all of that but the actual html code and BB codes are refused by the bulletin board program.
cb look at my sig line now
all I did was take out extra wording and added this to end [/url]
I copied whole post to notepad and then
I removed:
add this to end
remove the spaces in between brackets so it looks normal
and removed spaces in bracket, then copied and pasted into sigline
out of curiosity i just looked at mine again.
i believe the options on the signature dialog box have changed. when i did mine there was an insert link button. it was simple.
now looking, i no longer have that button on the signature dialog box.
fwiw
