CincinnatiNKYBuses
Hello all - I'm pretty sure I ran my CE on too little fuel (during a dirt track race, not on the road, thankfully). Did some work on it today with the track mechanic trying to get it going again.
Where is the relay for the fuel pump supposed to be? The fuse panel diagram doesn't seem to list it anywhere.
One mechanic recommended that I check three fuses in the battery box - but on my bus there is only one 40-amp fuse down there, and it is still operating properly. No other stub ends or wiring issues that I could see.
The only other thing of note is that mine has a second solenoid on the bottom of the fuse block - also not listed on the diagram - but I'm not sure if it's fuel pump-related.
I was able to find a diagram on here for a 2012 CE, but I imagine a 2003 is a bit different. Thanks in advance for any help.
