Look a bus!
looks nice and clean - that nose would allow good visibility when driving
The visibility of the 2nd Generation vistas are amazing. Flat nose may be a bit better, but in a pinch the vista is still better than the full dognoses I checked out and drove.
Can't even see the hood, you have to lean up a bit to see all 2 feet of it.
I like it. Mileage is good, 7.3s in a bus that size are just fine, the rear heat/AC is a bonus. For buses that length, I think its a reasonable price.
Hey everyone! I went to see the bus today. I am looking for more advice now that I’ve seen the bus. If I like what I’m hearing, I’ll go buy it on Monday.
So first off, the instrument cluster is having issues. No fuel gauge, no speedometer, the temperature gauge read as hot as it could go, but the engine didn’t feel that hot, the odometer stopped as well.
I have the records of it’s last 3 inspections and it has only moved 1000 miles since.
The underside seemed to a bit oily, not sure of where the oil may be coming from. Any ideas?
It is a California bus so it has an exhaust regenerator installed which has a green indicator light that does not turn off with the key. It seems to be draining the battery relatively fast.
The seller is taking it to a diesel mechanic tomorrow to see what he can have fixed up for me prior to purchase, no extra charges added.
Find out who the mechanic is and see if he'll go over the bus and find everything wrong with it.:thumb:
Instrument cluster issues are somewhat common. The most likely problem is cold solder joints on the circuit board.
I have seen quite a few that were repaired by simply resoldering the connections on the circuit board.
Find out the transmission. Is it probably an AT545. Never driven one, but I was interested in them because of the size. Heard they ride rough and the engine can be more difficult to work on vs. a regular dog nose.
Thanks! That is a relief. Most of what I read so far in my research says it’s common. I’m just more comfortable getting my information directly from here. :)
Some photos of tags and the regen light that’s always on as well as inspection records.
Some photos of the undercarriage so you can see the oily bottom. Hoping this is a simple fix. Really loving to shape and size of this bus.
Michael (co-potential bus owner) went to school for automotive repair, but does not have a whole heaping ton of experience with diesel. We are prepared for some hard work, and willing to drop new gear under the hood.
I’m going to see if I can’t get the info to the mechanic as mentioned above. Great idea! Thanks.
If I'm not mistaken the 542 is the same as the 545 only with a deeper pan. It is the least desirable transmission for a Skoolie.
