Looking for Cummins NH220 Radiator
hanaiapa
May 1, 2017
24
San Francisco
Hi All, I have a Crown 1972 bus (single rear axle, 5 speed manual) with a cummins NH220 in it. It's in good shape aside from the cooling system.
The radiator shows some corrosion and I'm looking for a replacement part, most probably a used one. Any pointer on the part specs and where to find it?
Thanks guys!
Thanks guys!
If you had filled in where your located we might find something for you within 4000 miles to you.
I live in SF and the bus is currently in LA.
I've heard rumors of radiators for busses costing as much as $5000.00 , In Ca with EPA regs it's hard to find True Raditor shops anymore But, In Woodland, Ca there is a Shop called Star Raditor he does a lot of work for the commercial farmers on their equipment he has a tank big enough that he was able to boil out my 112 gal fuel tanks, I would call & talk with him, ALSO in Redwood City
On Industrial Ave ( If I remember right) There's a shop but I don't recall if his tanks where big enough for a radiator that size. Look there before thinking about replacing.
What about tires, does anyone know the best place to get fairly cheap tires around SF or LA? The cheapest quote I got was $400 without install!
Size is 11,000 R 20
I recently replaced my bus's entire cooling system and had Atlas Radiator in Santa Fe Springs CA make me a new core. If your bus is in SoCal that's an option for you. Atlas made me a 6-row core a few inches taller than the old, with more tubes per row, dimpled tubes, and much denser serpentine fin count, all copper and brass, for about $1800. I reused my tanks after I had them powder-coated, and along with a new custom-made fan and hydraulic fan motor, a new hydraulic/PS pump, a new transmission cooler with fan, a new hydraulic filter, and much much else, I think I've finally got my overheating problems under control.
There's a wholesale radiator manufacturer in San Bernardino CA called Thermal Solutions Manufacturing, and their website has a lot of useful info on cores, tanks, gaskets, etc. They have a catalog online that lists radiator sizes and specs for pretty much any truck or bus ever made in USA. I remember seeing some different sizes of radiator for mid-engine Crowns mentioned, maybe one for smaller Cummins and Detroits and one for Big Cam Cummins?
You may be lucky to find a matching used radiator from a Crown being scrapped, as long as it's not a CARB scrap job. However, it's a crapshoot if it's any better than what you have now, and for all the work involved I feel it's better to get a new core, then you won't have any problems for the next 20 years or more.
Finding 11.00R20" tires will be a challenge! Are they the same diameter and RPM as 12R22.5"? Maybe you can find usable take-offs and wheels from a school bus being scrapped, but they would have to be the same ply rating and load range as your present tires to be safe, and the same diameter to keep your speed the same as now.
Re: Tires
Size is 11,000 R 20
Just got a quote today for 728 including tax for two front tires, mount, balance, and install.
J and O in Oakland. -A
