Iscalcrazy
- Joined
- Apr 9, 2024
- Posts
- 14
I have recently acquired a 1991 International bus with a DT360, At545 and a 5.38 axle ratio. I moved it to the home base. While in transit, I couldn't hear myself think because the bus was so loud. I was driving between 50 and 55mph. I think it was turning 2500 + rpms. That is insane. If I use the bus for a trip, it will be to the mental ward. Fuel consumption is probably much higher at those rpms.
So my question to all of you is, should I do an axle swap or transmission swap? I have an AT 1545 but that won't help lowering the rpms any because it's still 1:1 in 4th gear. I have seen rear diffs for sale for as little as $500 with 4.44 ratio. I do also own a Allison 2000 transmission but don't feel like going through the hassle of that swap.
What say you?
What say you?
