musigenesis
The wheel wells and the floor around it on my bus are tremendously rusted out, to the extent that I need to basically rebuild the entire floor from about two feet behind the wells to three or four feet in front of them. I have discussed this repair with my mechanic (a guy who also does a lot of custom vehicle modification) and we discussed the basic conventional way of rebuilding the floor, which would be to cut out the existing floor, weld in cross-members of some sort (3" high rectangular steel tube or something like that) running side-to-side from chair rail to chair rail and resting atop the chassis rails, and then a layer of 16 ga sheet steel on top of this, creating a replacement floor that is at the same level as the original factory floor (and joined with the existing wheel wells which are themselves OK other than the bottom 2" which is rusted away completely).
However, since I am planning on building a 3" deep insulated subfloor on top of the factory floor (2x4s with a half inch ripped off), I believe that there is a way to rebuild the floor section around the wheel wells so that the new sheet metal would be at the level of the top of the chassis rails (i.e. the bottom of the original floor structure) and the subfloor would be on top of this.
Basically, my idea is to run one cross-member beam behind the wheel wells (about where the fuel tank inlet is) and a second one about three feet in front (where the side exit door starts) and then remove all of the original factory floor in between. The removed flooring bears the weight of the rest of the body, so the two beams would need to be strong enough to bear the weight normally borne by the removed flooring (I'm thinking 3"x2" rectangular tube with 1/4" walls would do the trick, but I dunno).
I would then run two rails (possibly also 3"x2" tube but I think these don't need to be that strong) from the front beam to the rear beam, but these rails would be welded to the undersides of the beams (so that the tops of these longitudinal rails are at the same level as the tops of the chassis rails) and would run next to the chassis rails (on the left and right sides, respectively) in between them and the inside of the wheel wells. The new sheet metal would then be placed on top of these longitudinal rails (and also on top of the chassis rails), so when completed this section would be 3" below the original factory floor.
I would then build the wooden subfloor for this as a separate section on top of the new sheet metal, which would give me a fully-insulated floor section that would only come up to the level of the original factory floor (the front and back of the bus would also have the 3" subfloor but there it would be built on top of the original factory floor and thus be 3" higher). This might seem kind of not worth it, but I'm 6' and if I build a 3" subfloor and insulate the ceiling with furring strips, I'll end up with a ceiling that is an inch or two too low for me to stand up fully. With this "lowered" floor section, I would have an area for my kitchen, bathroom and dressing area that would allow me to stand up fully (these are the only things that I really need to be able to stand up for) and I would achieve this without having to do a roof raise.
Is there some reason this plan would not work?
