Mad Max
Biscuitsjam
Dec 23, 2017
611
GA
Since I'm bored staying at the house, I thought it might be fun for a more light-hearted thread.
How suitable would a skoolie be for a Mad Max scenario? Think nuclear post-apocalypse with lots of crazies wielding guns, spears, and razor-sharp boomerangs, fighting over every scrap of fuel, water, or food they can get their hands on. In Mad Max, vehicles are protected with turrets, spikes on all sides, crazy grappling hooks, and other such insanity. Rick Grimes also utilized school buses in his various wars against the survivors of the zombie apocalypse.
I'll start the discussion off talking about armor:
Weight:
The main consideration with armor is weight. My 1998 36-foot Amtran RE has a GVWR of 36,000 lbs but only weighs 20,000 lbs with a full tank of gas and a half-finished conversion. That gives me 16,000 lbs for food, ammo, water, armor, and attached wrecking balls. However, I figure that I could exceed that by about 10,000 lbs without mechanical failure. Sure, my crappy performance would be even worse, but I don't think it would leave me stranded by the side of the road. Offroad capability would be nonexistent with heavy armor. Another consideration is the center of gravity - putting steel turrets up top would make it top heavy, and even steel plate would likely make it unstable in uneven terrain.
Sandbags:
A full sandbag weighs approximately 40 lbs and is 8" x 16" x 4". You need 16" of sand to stop 7.62mm machinegun rounds, or a layer two sandbags thick. Heavy machinegun rounds require 32" of sand, or 4 sandbags thick. Clay is less effective at stopping bullets and requires twice the thickness as sand for the same level of protection.
If you wanted to add field expedient IED protection, you would need a double-layer of sandbags on the floor (8" of sand), at a weight of approximately 90 pounds per square foot under the feet of any passengers.
Protecting the entire floor and the entire wall of a 36 foot bus up to four feet high would cost you approximately 24,000 lbs / 608 sandbags for the floor and 57,600 lbs / 1440 sandbags for the wall, an excessive amount. Providing protection to a smaller area is feasible but would likely max out the suspension.
Steel plate:
You can stop 7.62mm with 1/2 inch steel plate, for about 20 lbs per square foot, or 5400lbs for the floor and 7200 lbs for the walls up to 4' high, a more reasonable amount of weight. 360 degree protection would weigh about 24000 lbs, depending on how you configure it. That would be possible, but wouldn't leave any excess weight capacity for food, flame throwers, or water filtration. It would likely make sense to use less or no armor on the roof. If you use hardened steel and line with kevlar, you can achieve .50 BMG (non-armor piercing) protection, equivalent to military vehicles.
Protecting against glass:
Glass is a hazard and should be lined with sandbags or otherwise protected against if not removed. Bulletproof glass is an option, but is both expensive and very heavy. Companies will let you custom order anything you want, but they wont give price quotes or discuss weight without a legitimate inquiry, so I can't do a decent estimate on price or weight, other than "a lot."
Fuel tanks:
They should definitely be protected. Although diesel is not easy to light, gunshots to the fuel system can quickly disable a vehicle. Sandbags are possible on a bus with a wooden frame but not very practical. Steel plate makes more sense.
Tires:
Run-flat tires are available. Auto tire inflation systems are an option on some buses but relatively rare. Either or both would increase the ability to survive a fight. However, it should be possible to escape a kill zone ambush with flat tires. You could add steel plate to the outside of the wheel wells but it would make tire changes much more difficult.
Turrets:
Two turrets at the bus hatches are feasible. A front shield would keep the weight down. Side and back protection increases weight dramatically, and you might need want to consider adding an electric motor. Otherwise, it would be very slow and difficult to rotate when parked on a slope.
Conclusion:
A bus simply can't handle the weight to be a fully armored vehicle, but it would be possible to make careful considerations of tradeoffs to armor vulnerable areas .
The high GVWR could let you increase survival against mutant zombie bikers, the walking dead, or other nefarious desperadoes.
forget the armor and all that.
just add infrared/thermal detection and some bad ass guns like the phalanx and some rocket launchers like the dragons.
both can track targets after fired.
if you keep them away then you wont have to worry about armor.
long range detection and prevention.
blow a hole through there ambush before they can spring there trap
But where will you get those? Before the apocalypse requires a lot of money and black market contacts. Or, a major assault on a military installation, which would invite a drastic response...
During the apocalypse requires taking them from folks that may be inclined to use them.
It would probably also require a fair amount of technical expertise to mount a phalanx system. I imagine that accuracy would be hurt from the bus suspension system, and you likely couldn't fire over the side without the risk of a rollover. Ammo usage would also be considerable.
A dragon is easier, since it is just a man pack system. You're adding a lot of explosives to your vehicle if you get hit though. Last deployment, I had a couple javelin missiles sitting next to me in my tent when Hezbollah fired 33 rockets at us... we started exploring other storage possibilities after that.
Well, any Mad Max preparations need to be practical, good sir! How can any of us survive the apocalypse if we're hoping for miracles?
Just come up with a feasible plan for getting phalanx systems. Maybe a raid on a naval construction yard just as the apocalypse starts? You'd have to be lucky to have the weapons installed but the ship not yet delivered... of course, the ammo wouldn't be with the system until it was deployed... Hmmm, there's got to be a way... if only I was an international arms dealer...
M2 machine guns are at your neighborhood armory though - it seems like those might be easy to get your hands on. Ammo is available for sale in the civilian world right now.
A better course might be to just hide. Solar panels, water filtration, massive food storage...
If you have to travel though, it's always best to have a wingman. It greatly increases your chance of surviving an ambush, and gives you options in case of a breakdown.
SNIP.
Well, since you're already trying to take the 'fun' out of your own thread...
With your background, I think you already know...
Hardening a bus is a poor choice and only makes a poorly defense-able hard target...
There's a reason Rangers lead the way...
Now, lets say the covid-19 mutates and kills 90% of the population leaving a lot of stuff lying around but no infrastructure to maintain it...?
For your fuel tank and minimal armor needs think aircraft parts.
The fuel cells on my beloved Huey for example are ~100gal self sealing against 7.62 rounds. this is accomplished by a double walled tank -- in between the tank is a polymer ooze -- it's good stuff!
The armored pilot and copilot seats each weigh about 200 lbs iirc -- they're a ceramic kevlar bucket basically.
You'll need a run-flat tire system like CTIS
The armor kit we put on a C-130 before flying to the AOR is ~1.5" thick -- weighs about 2000+lbs and covers the entire flight deck floor and walls up to the windows.
The 'glass' on this puppy was 3" thick. Despite the size, there was only room for 4 people inside...
Serious armor takes up serious space... Thank goodness the a/c in this thing rocked!
There have to be a few ground rules, or we'd all be driving Abrams tanks!
Hmmm, armored seats are an idea if IEDs are a threat. The modern ones have shock absorption also...
I love Rangers, but some of them like to drink their own koolaid. how hardened do you think is reasonable then?
This is YOUR party -- your parameters are...?
I was just pointing out a couple things -- the acft world uses strong, lightweight, reliable components -- thus the high cost of acft parts...
Takes a huge supply chain to maintain an Abrams tank or any helicopter...
You won't be driving around in one for long...
Decide how broken your supply chain is...?
"Without Maintainers, Pilots are just Pedestrians with cool sunglasses..."
you can prep all you want and you can complain about how hard it is to get?
if you want it pre event then get it?
i will wait and get mine from the ones that bought all the stuff and didnt know how to use it or juust bunker down and take the spoils of war. OOHRAH
So, ground rules:
1. This is a mad max type world. Nuclear war leaves people short of stuff and lots of folks dead, supply chains broken, etc. Over time, things descend into having violent biker gangs roaming the countryside and trying to take everything of value. You discover this is the inevitable after having a revelation that the Mad Max movies are a documentary. You ate a contaminated can of beans and spent 24 hours having psychedelic visions. These horrible events will come to pass in about 4 years, but you need to stay mobile to survive.
2. You can start building now based on what is actually available, based upon the resources, skill, etc. you could conceivably scrape together if you knew this was coming.
3. You can complete your build after the apocalypse with other materials (heavy weapons, etc.), so long as you have a reasonable plan for acquiring them.
4. Your design can range from practical (long-term boondocking) to serious (armored cab and lots of weapons) to whimsical (wrecking ball crane on the roof and spiked wheels), so long as the design is something you could actually make and would actually work.
Ooooohhhhh I like it! I do not know if I'll have many ideas or suggestions, but this *is fun*!
I think I'll just drive my bus to WDW (Florida) and hide out on Tom Sawyer's Island in the Magic Kingdom! Nobody will ever think to look there!
**** i’m just gonna hide out here in the sticks of South Texas !!!
not steel armour but kevlar.... and lexan
I think multiple layers of kevlar cloth, would also add an amount if insulation. use a combination of kevlar cloth and kevlar sheet.... the sheets are layers of cloth impregnated with epoxy, I have been told that kevlar does not "wet" to epoxy very well. I kevlar "plates" or "sheets I think would be cut by water jet. any "glass" replace with 50mm thick lexan.
I would choose lexan over glass because the glass is nearly impossible to see through after the first round makes contact. The lexan, in my opinon takes more damage before you get to the point you cannot see through it....
If the outer layer can have any kind of hardness to it, getting a projectile to break up or flatten out, would then, make it more difficult to get through the layers of kevlar.
use of multiple cameras would elimiate need for windows, but a way of replacing damaged cameras would have to be thought up ..... hiding location of cameras would make it more difficult to "take out" cameras, If you cant see them you cant shoot at them.... thousands of options including radar...
ultrasound, heat, blah blah blah...
masking a bus from these detection methods gets into some interesting discussions......
william
On one hot night in Iraq, I saw two young men covered themselves with a half dozen blankets while overwatching an IED. Their heat signatures were diffused but still very obvious, particularly their faces.
There are ways to defeat thermal imaging, but it isn't easy. Far better to place yourself on the other side of a barrier like a wall or a hill than try to mask your signature. The military likes to use camo nets - it's still obvious something is there, but it makes it hard to tell if you're looking at a T-90 Main Battle Tank or a Ural truck.
william
Interesting thought on lexan... it's probably better than glass if damage is likely, though still far from ideal.
I don't think you'd ever want cameras as your sole method of seeing outside, but they'd work well if you have an alternate method also. What about using periscopes as the alternate method? It's what military armored vehicles use.
On the front of your bus, you may want to build some sort of cable cutter. Something that would scoop up a cable blocking the road and guide it into the cutting jaws.
As far as armor...steel plates in strategic locations...protect fuel, tires and people.
I highly recommend reading "The Patriot" By James Wesley Rawls. It would make a great movie...
