skuld
- Joined
- Jul 21, 2017
- Posts
- 39
I finally had a chance to get the bus to the mechanic to get a clean bill of health. Everything looked good, other than the short list below, and once they put on new back shocks, she will be back home and the work begins.
<b>Backstory:</b> and why I decided to embark on this crazy adventure. I currently live in Alabama and will be moving in about a year. I actually have no idea where I will be moving to within the states, but I know I'll have a month or two to get there. Me and my wife had looked into getting an RV, and entertained the thought of living in the car during that time. We have two pups, and know that there will be times when they have to be left alone, so the car is out since they will certainly need A/C if they're going to be in there for an extended period. After much research and consideration, we realized the best (and most fun) way to do this would be to outfit a short bus.
If money were no option, we would go with a sprinter and have a fully offgrid stealth conversion, but that ends up being impractical once you start looking at the cost. So we started looking for a bus. Craigslist was definitely my preference to find a project that was ditched halfway through to avoid the initial work. After a month or so of watching, we got lucky and found one within 3 hours of us. More on that later, but without further ado, here is my bus in all her glory:
busted window, but this will probably be covered anyway.
Will is ready for an adventure!
<b>Before: </b>Like I mentioned, this was a previously started conversion. The previous owner was an older gentleman who was outfitting it for a trip across Route 66, but his wife unfortunately died and he mostly lost the will to finish the project. Before that, it was actually a raft bus on the Ocoee River and was mainly used to haul trailers through the mountains of North Carolina. I'm assuming that it was a school bus before that, but who knows what this bus has seen in its 25 years.
The conversion that had been started was basically taking parts out of a salvaged RV, with a bit of work done on the mechanics of the bus as well. The bus had replaced the dually back tires, exhaust headers, front shocks, A/C switch, and other general maintenance. The conversion that had been done included ripping the seats out and installing a 3.5kW generator, 30gal water tank, RV power inverter, water pump, shower, stove, sink/countertop, shelving, and bench/bed. You can see most of this in the image below, but unfortunately I did not take a picture before I got to cleaning it out. Most of the work was not done with rgard to plumbing, electrical, propane, or anything like that, so I felt a little less bad for ripping out all of their hard work.
And all of it currently sitting on my front porch
<b>The Plan:</b> You can see my sketchup below. I have not fully committed to the two captains chairs, and we might even keep something similar to the bench that is currently in there, but the main objective is a safe place to sit while driving. We don't currently know what we are going to do for a table, but I'm thinking that a little foldup tv table will do just fine.
We plan on having a pretty high lofted bed that leaves us with about 2.5 ft of clearance above our heads. The divider you see under the bed will essentially create a trunk that we access from the back door. I think we will also create a wall on the backside of the bed, such that the trunk is only accessible from the back door. The trunk will contain all the power electronics and the water tank, and will also serve as storage. We also currently plan on removing the back two windows for better insulation, and just having these covered by sheet metal.
On the kitchen side, you can how we plan on essentially just having a sink and a stove (which is currently drawn as mounted, but we will probably just buy a portable induction stove because they're cheaper. Still more research to do on that) with a fridge underneath it. The pantry will double as a night stand for the bed, and we will also have some overhead storage as well. And of course a TV mounted either behind the driver or above the windshield.
The other wall is mostly empty. We might do overhead storage, depending on what things feel like, but I honestly thing we have enough storage as it is. You can see the drawers that I plan to install on top of one wheel well, and the other open are will mainly just be for dog kennels and space for storing big things like a composting toilet. We also currently plan on doing a window mounted unit, which might be built into a box in order to bring it inside the bus more than it currently is.
There is a decent amount of wiggle room in this plan for things like the A/C, water system, thermoelectric cooler instead of fridge, etc. etc. And ther is of course a ton to nail down on the water and power systems. I will most likely set up the power system to have a pretty robust system that will allow me to be off grid for up to 8 hours at a time, but I might lower the water requirements and simply have a foot pump for the water and a grey tank underneath the sink.
<b>Next Steps:</b>
Engine:
Transmission flush, might pay someone to ensure it's done right
Fuel Filter change
Belt change, and maybe tensioner as well as I have a small squeak
Battery
Exterior:
fixing windows, many broken latches
sanding and painting some small surface rust on the back and where a spot was cut for the generator exhaust
sanding and painting the wheels, as they have a noticeable amount of surface rust
sanding and painting a lot of the metal bars that have rust, like the mirror mounts
mounting sheet metal over the back two windows on each side
Interior:
I have not decided if I want to insulate the roof or just below the windows. I know what I SHOULD do, but I'm hoping someone will convince me not to be lazy.
removing paneling up to the bottom of the windows
removing back two windows on each side.
removing floor
Insulation, subflooring, etc.
So yeh, the main next step is doing flooring and insulation. I am still doing some research now, so any relevant threads or tutorials people have would be great.
I will keep this thread updated throughout the process once I am set on how exactly I want to do certain things, then how I want to move onto each new step. Definitely looking like it'll be a fun project.
<b>Next Steps:</b>
Engine:
Fuel Filter change
Battery
Exterior:
Interior:
removing floor
