I've lost count of the actual days at this point, because it's often been short bits of work throughout the week. I've mainly been doing trim work. Boxes for the generator, wheel wells, and batteries; window sills; corner trim; wood putty; paint; blah blah.
To cover the generators, wheel wells, and batteries, I mainly just made a frame then used 1/2" plywood to make a simple box. I insulated the generator box with extra xps foam that I had. I was even able to use 1" and 1/2" to really clean out my garage. I doubt it will do anything, but I figured it might help a touch with noise and heat. May eventually cover it with soundproofing or something, but no plans right now.
I was originally going to put the batteries along the big edge of the generator box. My wife suggested putting it on top of the wheel wells instead of putting accessible storage there.
After testing it, I realized it is pretty much a perfect fit for the battery box to line up with the genset box. There is an inch or two of extra space that is wasted by making it flush, but that's going to help me if I ever need to access the batteries anyway. I put down some wood to put the batteries on, and I sealed the edges real well with polyurethane in case of some leak or something. I'm a bit concerned in the case of an accident, but I think the batteries can be held down well enough with the lid.
This shows the wall between these boxes. This space is a bit wasted, but that awkward angled space would be pretty worthless no matter what I put there. I'm going to put a 2.5" port to the outside and a computer fan to help vent the box. The wires to my alternator will also run through this wall.
All in all, I'm really happy with the current look of it. It's going to eventually be covered with electronics, but it's a pretty sexy box. Just need to add a hinge and latch to the top of the box.
At one point we were going to have real window sills, but decided to use 5.0mm plywood underlayment because we already had it and thought it would add a nice touch to the light look of the current setup. I really liked how it turned out, and it did well to cover. I did have to sand the back edge just a bit, because I forgot to think about the window having to come down and it was about 2mm too deep. Took awhile to sand it down by hand, but what can you do.
I also wanted to add corner trim to cover my exquisite craftmanship. I had up to a half inch gap in place.
We messed around with stair edges and wood trim, but ultimately decided to use 3/4" aluminum angle iron (angle aluminum? Is that a thing?) to match the kitchen and I am really happy with how it looks.
Still need to cut the one for the window sill, but I'm not sure if we're putting on on the front edge just yet. It depends on the couch situation, and whether we can fit a little divider wall there to help hold everything in place.
Decided to go with a little
ikea loveseat to give space for the dogs and my wife that serves the purpose a little better than a bucket seat. Going to install some seatbelts, but I haven't decided if it's best to secure the belt to the couch or the bus. Can't decide which is safer in the case of an accident.
Next, I'm adding in a shelving unit between the bed and the kitchen. This will also serve to hold in the kitchen real well since it's light. I'm also about to start the electrical. I don't want to admit it, but I have an electrical engineering background. For whatever reason, this means I'm more nervous about electrical work. With cutting stuff at least I can say "eh, not bad for an amateur." But with electrical work, I am paid to already know what I'm doing (though admittedly, I'm in software and been in computer science for the past few years and have never really done car work).
Here is my electrical system in its current state. Going to rely pretty heavily on DC for lighting, electronics charging, a fan, etc.
-Solenoid to connect to the alternator (50A fuse), house and engine grounds tied together. Currently getting a mechanic to decide if I need a bigger alternator. I think it might only be 105A.
-Battery meter which will be on the edge of the battery box.
-1200W inverter that also has an A/C transfer switch (I have an add'l 3000W inverter in case I ever want to connect the AC to the batteries. I got it for free, but I'm only going to use it if I add in the solar.
-DC fuse block (125A fuse) to distribute my lights, fan, electronics, etc.
-5-stage 30A charge converter (250A fuse)
-small A/C that fits in the bus window.
I also have a nice big switch to disconnect batteries, but I'm honestly not sure what I want to do with it. House battery, engine battery, or solenoid bypass in case of dead engine batteries (though I think I could just jumpstart)?
The circuit above has a circle to indicate the nice-to-have items. I prioritized an alternator hookup since we will be quite mobile and can keep our batteries charged while driving. Definitely going to get the other stuff before going on the trip. We would love to have A/C but I'm thinking it's going to be much more difficult than we're imagining. We picked up a maxxair fan at the recommendation of people who live out of their van. Supposedly I can keep it comfortable enough in temperatures from 50-80 with just a fan. Will eventually pick up a window unit to use with the generator/shore power, but wanted to do some "bus tent" camping to test how the fan affects temperature.
I forgot to draw my potential solar setup in there. I really want 500W solar, but I want it on a roof rack, and know it will probably cost upward of $1500 to get what I want. I really love the idea of boondocking, but I'm just not positive it's worth the price. I've rationalized it a bit by thinking of a grid-tie inverter to add to my house power when the bus is parked. I'm thinking this would also be good for the batteries to stay fully charged.
The electrical system has definitely been something I've dwelled on a lot. One of those things where I could do it cheap or right, and I have no idea which way it'll end up. I have 6 weeks or so before the trip starts, so I really need to start nailing stuff down.
I'm working on the exact route of the trip as well, and I'll update once it's done. Hoping to see Glacier/Banff and also Yellowstone. Coming from Alabama, it's going to an ambitious journey to make it that far and still see all the parks along the way. 4 weeks is simultaneously a long trip, and such a short trip.
