Rock-N-Ruth
This is our bus:
These are some of our solar panels:
This is our home and it is a work in progress. We have been depending on the sun for our electricity since 2011. One of the factors that affects solar panel efficiency is heat. Kinda funny that it takes sunlight to make the electricity but the heat from that sunlight slows the process. I have an idea that might add some efficiency and produce some hot water.
On any given day the temperature on the underside of the panels runs about 110 to 125 degrees Fahrenheit. For more than a year we collected hot water by laying a roll of black irrigation pipe on the ground and letting the sun heat it up. It gave us nice hot showers by 11 am. No fancy solar collectors, just $15.00 worth of plastic pipe and a garden hose. So, why not do the same with our solar panels?
I haven’t got the whole thing worked out but I am thinking using the same cheap irrigation pipe to make a heat sink under each solar panel and connect them together in series. Circulate water with a low volume pump to a storage tank. The storage tank can feed my hot water tank and thus any captured heat can be used to wash dishes and take showers. In the mean time it is also reducing the temp of the panels a bit allowing them to produce just a little better.
