I'll talk about what I did and why.
bus - rounded butt, no roof air or hatches or decks. Why? Trailing side shape for aerodynamic. I know it is not a lot. I also know that, .5% here, 1% there, adds up and does make a difference.
Future modifications include under tray and air dam up front and belly pan along the body, along with tighter fitting fender liners. Yes quite a bit of work for diminishing returns.
I know that at 65mph, my intended cruise speed, I can reduce turbulent air flow under the bus. I might be able to reduce some of the turbulent air flow on the side of the bus. The front? Not a lot that I am seeing, need to do "yarn testing" to find the messy air flow and see what I can do about cleaning it up.
Rear end gearing--- I am aiming to put the engine at lowest engine rpm on flat level ground, with out bringing the engine to a "lugging" condtion.
3.73 rear gears, 245/70-19.5 tires... calculated engine rpm at 65 mph is 1875 rpm. I am changing from 225/70 19.5 and old rear gears were 4.88
engine -- funny thing here is, with diesels, the fuel you burn is the power. So if you burn 100,000 btu per mile with a 5.9 or burn 100,000 btu per mile with a 8.3, or 100,000 btu per mile with a 10.0..... mileage does not seem to vary a bunch with engine size. I have a smaller engine because it fits the engine bay easier. I started with no engine or transmission in my bus.
I have hopped up my bus engine, more fuel, bigger turbo charger, changes to the engine to take more turbo pressure, The only thing I think would increase mileage though, might be more turbo, and advance injection timing. I have not done testing yet on best fuel economy vs power I want going up hills.
future project... That big honkin cooling fan, Really want to convert that to one of the newer electric clutch jobs. Also in the future is moving power steering to an electric pump power steering, and link to speed, more speed = less pump pressure. Dont need power assist at 65 mph. Want all I can get in a parking lot.
side view cameras and itty bitty mirrors. -- that might change as time goes on. If I have problems with not being able to see well enough, or the police have a problem with my electronic mirrors.
Radial tires in stead of bias ply. -- Also running pressure of tires according to weight they carry, so much less than maximum pressure listed on the side wall. Tread pattern, those blocky treads pump more air, I have what would be called "shitty for the off road" tires. I could well see my self stuck on wet grass on a mild incline. But better highway mileage.
Six speed manual transmission -- mostly because less moving parts, usually mean less to go wrong. but, I like the gear spread and has .73 overdrive. First gear is low enough to get me moving from a stop on a hill. Dual disc clutch to take the extra torque the engine can put out if I am feeding all the fuel it can take.. extreme case around 700ft/lb to 800 ft/lbs estimated.
But with the way automatics are usually built, I think the manual will absorb less power operate.
with out the under tray stuff, fender liners, small mirrors, fan clutch, or electric steering pumps... This kind of bus gets 12 mpg all the time on the road. in town less..... but paying attention and such, when I get more miles on it, I expect to see 14 to 17 mpg at 65 miles an hour...... I think I might be able to get 18 to 19 when I call it "done".
This is a game for me. Something I devote my free time because it is fun for me to see how far I can take it.
1954 ford Wayne body, sitting on 2005 ford 450 chassis, cummins 5.9 12 valve engine, with NV 5600 six speed transmission, 3.73 rear end gears, steel rims, 245/70-R19.5 michelin hiway ribs. Steel wheels. Big job F700 front fenders. The front axle is as wide as the rear axle. The outer dimension of the tires is about 4" wider than the 1954 chassis. expected total weight with hooligans 12,000 lbs
william
Type of transmission and rear end oil .. synthetics ... much thinner viscosity wise = less drag.
