pattern, couple of end caps and it's in like Flint.
The phrase isn't 'in like Flint', it's 'in like Flynn'.
And locking pliers aren't vice grips, they're vise grips.
And locking pliers aren't vice grips, they're vise grips.![]()
I'll talk about what I did and why.
bus - rounded butt, no roof air or hatches or decks. Why? Trailing side shape for aerodynamic. I know it is not a lot. I also know that, .5% here, 1% there, adds up and does make a difference.
Future modifications include under tray and air dam up front and belly pan along the body, along with tighter fitting fender liners. Yes quite a bit of work for diminishing returns.
I know that at 65mph, my intended cruise speed, I can reduce turbulent air flow under the bus. I might be able to reduce some of the turbulent air flow on the side of the bus. The front? Not a lot that I am seeing, need to do "yarn testing" to find the messy air flow and see what I can do about cleaning it up.
Rear end gearing--- I am aiming to put the engine at lowest engine rpm on flat level ground, with out bringing the engine to a "lugging" condtion.
3.73 rear gears, 245/70-19.5 tires... calculated engine rpm at 65 mph is 1875 rpm. I am changing from 225/70 19.5 and old rear gears were 4.88
engine -- funny thing here is, with diesels, the fuel you burn is the power. So if you burn 100,000 btu per mile with a 5.9 or burn 100,000 btu per mile with a 8.3, or 100,000 btu per mile with a 10.0..... mileage does not seem to vary a bunch with engine size. I have a smaller engine because it fits the engine bay easier. I started with no engine or transmission in my bus.
I have hopped up my bus engine, more fuel, bigger turbo charger, changes to the engine to take more turbo pressure, The only thing I think would increase mileage though, might be more turbo, and advance injection timing. I have not done testing yet on best fuel economy vs power I want going up hills.
future project... That big honkin cooling fan, Really want to convert that to one of the newer electric clutch jobs. Also in the future is moving power steering to an electric pump power steering, and link to speed, more speed = less pump pressure. Dont need power assist at 65 mph. Want all I can get in a parking lot.
side view cameras and itty bitty mirrors. -- that might change as time goes on. If I have problems with not being able to see well enough, or the police have a problem with my electronic mirrors.
Radial tires in stead of bias ply. -- Also running pressure of tires according to weight they carry, so much less than maximum pressure listed on the side wall. Tread pattern, those blocky treads pump more air, I have what would be called "shitty for the off road" tires. I could well see my self stuck on wet grass on a mild incline. But better highway mileage.
Six speed manual transmission -- mostly because less moving parts, usually mean less to go wrong. but, I like the gear spread and has .73 overdrive. First gear is low enough to get me moving from a stop on a hill. Dual disc clutch to take the extra torque the engine can put out if I am feeding all the fuel it can take.. extreme case around 700ft/lb to 800 ft/lbs estimated.
But with the way automatics are usually built, I think the manual will absorb less power operate.
with out the under tray stuff, fender liners, small mirrors, fan clutch, or electric steering pumps... This kind of bus gets 12 mpg all the time on the road. in town less..... but paying attention and such, when I get more miles on it, I expect to see 14 to 17 mpg at 65 miles an hour...... I think I might be able to get 18 to 19 when I call it "done".
This is a game for me. Something I devote my free time because it is fun for me to see how far I can take it.
1954 ford Wayne body, sitting on 2005 ford 450 chassis, cummins 5.9 12 valve engine, with NV 5600 six speed transmission, 3.73 rear end gears, steel rims, 245/70-R19.5 michelin hiway ribs. Steel wheels. Big job F700 front fenders. The front axle is as wide as the rear axle. The outer dimension of the tires is about 4" wider than the 1954 chassis. expected total weight with hooligans 12,000 lbs
william
Type of transmission and rear end oil .. synthetics ... much thinner viscosity wise = less drag.
You have a bus. Taking any one of the inline 6's,(because let's face it, everyone has their own favorite) coupled to an Allison 545AT (with the future ability to upgrade to a 643), what's the 1st thing you do to make it more "highway" friendly? By that I mean getting better milage, not having the thing screaming like a porn queen in her best film yet, and keeping it with in the comfort zone of RPM's and a speed of no more than 65. I only say 65 because the old 55 is now 65. That and that's the most you want or need to push these things anyway. I'm curious to see what kind of responses I'll get.
the only automatic I know of wit ha creeper gear thats a mechanical is the allison 653, essentially a 5 speed 643 but first is a creeper..
once you get into the 700 series you get into SAE1 mounts which are a PITA on medium duty..
if I needed to creep, id do an allison 1000 and a 2 speed rear end..
Another option not mentioned is an auxiliary transmission. I recently purchased a Spicer 7231D which, when installed will give me a 2:1 underdrive, direct drive and .86:1 overdrive. My 4.78:1 gear ratio at .86 gives me 4.11:1 in overdrive. If I swap out the differential for a very commonly available 4.44 I'll get 3.82:1 in overdrive. This setup gives me a lot of options for different driving conditions without compromising.
I have a spicer 5831B in my truck, same ratios as you mention. I think it is great and gives lots of gears available. However it is not syncronized so I have to really pay attention when shifting to get engine rpms just right for it to go in gear without grinding. Not so sure how it would shift behind an automatic.
Does the 7231 have syncronizers?
There are some neat videos of "twin stick" shifting on youtube.
53 years ago I drove an old at that time, B49 Mack - had 2 trans, a 5 and a 4 speed - the old gas pot had spent it's life doing short hauls between the saw mill and the railway siding where lumber was loaded into box cars - my job evolved into longer trips to service some mines ( 20 - 25 miles ) lots of steep hills with heavy loads - the 5 gear transmission was so loose it was sloppy and not always easy to find the gears - the 4 speed trans had barely ever been used and was still tight - trying to shift the two transmissions smoothly together was almost impossible because the 4 speed would slow or stop spinning while the 5 speed took for ever to slow down - I never was able to do an 'arm through the steering wheel two handed shift' of both transmissions at the same time - I had to resort to shifting one transmission, then the other, which didn't work great on the steep uphills, or gearing down on the descents - when I was loaded, it meant stopping completely to gear down before crawling down the hill - wasn't a pleasant truck to drive - tough old beast though
