Thank you very much.
My 10 speed is taller, enough so that a large crossmember is in the way of trans installation into the clutch. I lifted the front of the engine to tilt it and allow a tilted trans to install, then raise up in front of that crossmember. My trans jack is leaking making accuracy nearly impossible.
I'm probably gonna cut out the section of floor above the trans due to lack of clearance with the top of the trans, and the fact it will need a hole for the shifter tower.
Oh, the muffler was in the way of install too. Will it fit if I can get the trans in? Time will tell.
Moral: after finding the correct clutch housing, flywheel, flywheel bolts (M12-1.25 x 40) I thought I could bolt it all together in a few hours. WRONG. Still fighting it.
send pics, it will be very cool to see this all in. you will have a crazy cool set up with 10 gears.
in the end the SAE housing is a pretty beefy piece of iron. Now was yours designed to hang 600lbs of it with no support. I cannot say. I have never crossed part numbers to see if international had a housing designed specifically for what your doing.
Other thought that comes to mind is the engine mounts, is your current mounts designed to support the extra 600lbs hanging off the back? I don't know.
It may sound like I'm back tracking here but to answer your question, do transmissions have supporting members. They do and they don't. It all depends on the powertrain set up and manufacturer.
To be better safe then sorry, you could make a member to support the extra weight.
That spring that I showed a picture of, each end sits on bracket in the shape of a piece of angle iron that is bolted on the inner side of the frame rail. on each end of the spring MIGHT have wearable plastic wear pad. occasionally they get replaced but they were cheap and easy. In the center of that spring there would be two 3/4 inch holes. One would take some 3/4 inch bolts(15/16 wrench head) and run that spring down into the trans housing. the spring would flex essentially carrying weight off the sae housing and rear engine mounts. The spring would deflect when bolted down to the housing at least an inch if not more but that is thinking back 20+ years ago. Everything I work on now has Alison 4000 series transmissions for the most part.
If you look on top of your transmission housing, do you see 2x3/4 national coarse threaded holes on top? if you do you can incorporate this spring I refer about to pick up some of the weight.
For the spring that I am referring about, search a 1998 Kenworth T800. The fleet I worked on back in the day had Cummins N-14's with 13 speed transmissions. I'm sure they came with other set ups but we ran the same powertrain on the 150+ trucks we had.
Hope this helps and makes sense.
