Hi guys, we are getting ready to go out and purchase our materials for starting our Crown Bus conversion. I am looking to insulate the sidewalls and the floor and then cover everything with Either Marine Plywood, HDPE Panel, or Exterior ply. The issue I am having is obviously the costs. Based on our calculations to cover the side walls and the floor with Marine Plywood it would cost almost $700-800 for 3/4 thick Marine Ply. I have seen HDPE panels for a little less for 1/4 thickness (Now I know HDPE is stronger than Plywood so I am not sure if this mean its okay to go with less tickness) I would gain the no rotting risk and purely waterproof. Then there's Plywood with X rating such as ABX or ACX or CDX. What would be your recommendations if I want to save a little bit of money but still be well protected from possible water damage. Knowing how these buses can and will always have water leak issues from rain etc I obviously don't want to skimp out but I also don't want to break the bank. I am also thinking of using the HDPE and Marine as combination, perhaps the Marine as subfloor and the HDPE as the side walls that are behind the cabinets etc or vice versa
Marine Ply
https://www.menards.com/main/buildi...ab-marine-plywood/1251600/p-1444452503795.htm
HDPE Panel
https://www.menards.com/main/buildi...-4-x-8-hdpe-panel/1295030/p-1444424093657.htm
BCX Ply
https://www.menards.com/main/buildi...cx-sanded-plywood/1251049/p-1444431327232.htm
Marine Ply
HDPE Panel
BCX Ply
