What in the ignition system could cause a large enough voltage drop to not let anything function I took off the battery to test them and the starting and hooked up the grid heater to a manual push button cause it wasn’t working and it’s been very cold lately and when I put the starter and battery’s back on every time I turn on the ignition there’s a huge voltage drop at the ignition battery terminal on the ignition switch and nothing works however if I turn it to acc position no drop and the grid heater is unhooked so it’s not that
