Atridox
- Joined
- Mar 23, 2010
- Posts
- 25
Took my finished 86 bluebird middie (7 wondows), Chev C-60, 350 engine, for a long road trip (12 hours at about 60-65 mph. A couple of things came up:
1. I got 5.2 mpg. I had the bus tuned up, oil changed and new tires before the trip. Is this low mpg normal? Can I do anything to change it? It cost me $410 in gas today.
2. The HurryHeat valves were closed under the hood. However, the hot air blowing off the engine onto my legs in the driver's seat was stifling. Can I put some insulation behind the pedals to cut down on this heat source.
3. There is a leak on the power steering pump. Is there somewhere I can find a new or rebuilt one>
4. As noted above, I had the bus tuned up and oil changed prior to leaving on my trip. I checked the oil after the first 140 miles and it was down a quart. I ended up having to add a quart every time I stopped for gas. I do not see anywhere it is leaking. Can a bus burn that much oil or should I look harder for a leak?
ALL help will be appreciated.
T
T
