Hey Everyone,
After four long-ish years, my build is 98% complete. It's a 35 ft. pusher with 3K watts of solar, over 15K watt hours of battery, and two 3K watt inverters. One of the last things to install is the mini split. I was hoping to delay the installation for a bit, but it was just too damn hot on our first shakedown trip. Everything worked great though!
So I'm here hoping to get advice from some HVAC pros for my mini split installation. I have a dual zone 18K BTU system that uses R32 refrigerant.
Question 1: R32 has a safety classification of A2L - lower burn velocity and lower toxicity. What reservations do you HVAC professionals have about using this in a mobile application knowing that the refrigerant is flammable?
Question 2: If the consensus is that it is too risky/unsafe, can an A1 refrigerant and oil combination be used instead? The unit I bought is for professional installation, so nothing is pre-charged. Or should I just return it and buy something that uses non-flammable refrigerant?
Thanks in advance!
Thanks in advance!
