I finally put together a tutorial on how to modify the windows in my Thomas to open from the bottom like regular double hung windows. Video and pics are here:
Bus Windows that Open From the Bottom
I was wondering the same thing,Would this procedure be the same for a Bluebird? I'd love to have a few open from the bottom.
but you still have to wear the hatGreat Mod!!!
Seems like doing this on a homemade carpeted easel (scrap lumber) leaned up against a wall would make it easier than a workbench table top.... you'd be laying the window assembly on a little bit of a tilted surface. Swivel rolling chair, work on right side, then left side, and lay each rail beside you..., modify, then reassemble:hide:
I mean, once you get one done.... you got 29 more to go! (23 in vonslatt's case)
might as well get comfortable, you're gonna be there a while:ermm:
or a folding ladder with a ledger board attached
I can't stand over a workbench that long![]()
Do they leak water after?
Nat
I got this!!!![]()
dang..... you make it toughNo no, you need a lightweight fedora
