lapeer20m
I'm really kind of opposed to "turning up" the power on your engine. Everyone knows that more power = less reliability and durability.
I was looking at the DT 466 engines the other day, and found a sticker on top of the valve cover. It has a little chart showing what the timing and fuel delivery rate should be set at for vairous hp ratings. That got me thinking.....
So i looked for info about my engine and found that the DT series, my brazilian ford, and the cummings mechinical injection 5.9 liter engines all share the same injector pump. (different sizes obviously) It seems most diesel engines come with a lower hp rating for the first part of their life then can be turned up after the engine is broken in. Even though my particular engine doesn't have the info for increasing hp rating, i found the instructions on how to "turn it up". It seems simple enough.
I think it's a bad idea. My engine has over 276,000 miles and i'm sure that it does not need any extra stress.
That being said, I think that when the weather warms up, i'm gonna give it a try. What's the worse thing that can happen? I shoot a rod through the side of the engine block? Then i'll be forced to get that new bigger engine i've been wanting.
It seems like a bad idea....but i just can't resist! I'm a crackhead!
The 6.6 liter ford seems to be way overbuilt. However, i immagine it's come to the end and perhaps surpassed it's rated engine life.
What everyones thought on this?
It's not like i'll be increasing the hp excessively. Perhaps just 10 or 15 hp. I won't really know how much, it's not as if there is a skoolie dyno in my backyard. IF i get real ambitious, i might even put a pyrometer in the exhaust manifold to monitor exhaust temps before/after the modification.
