RebelWithoutACausey
Im getting towards the electrical rough in phase of my build and im torn between two generator options. I have to decide fairly soon, so looking for opinions of those who have experience with one or both.
First option, I have an Onan QG 4000 genset pulled off an RV with 100 hours on it. Option 2, I also have a Honda EU2200i portable generator. My electrical system currently consists of 2600w of solar, 10.2 kwh of lithium. All of my appliances will be electric.
Onan Pros:
-Mounted underneath, out of sight, out of mind
-4kw output
-Can be connected to my Cerbo GX to auto start when my battery bank gets low, wont have to think about it.
Onan Cons:
-I will have to buy and hang a gas tank, the control panel. Probably $600-800 worth of additional infrastructure just to use it. Im already blowing my budget on the build.
-PITA to work on or service, unlikely to be able to fix on the fly should it go down
-Expensive to replace
-Drinks 1/2 gallon of fuel per hour
Honda pros:
-Quiet as a church mouse
-Uses 1 gal of fuel in 8 hours
-I can tear it apart and fix it on the fly with like 4 tools
-Easy to replace if needed
-Doesn't require any additional infrastructure to be installed
Honda cons:
-Not weatherproof (big one)
-1/2 the watts
-Cannot be set up to auto start
If you were in my shoes, what would you choose and why?
Thanks!
Onan Pros:
-4kw output
Onan Cons:
Honda pros:
Honda cons:
-1/2 the watts
Thanks!
