BigBusParts
- Joined
- Jan 7, 2011
- Posts
- 7
Howdy!
I'd like some feedback on mounting a rooftop A/C unit on a 1990 Bluebird TC2000. My concern is that the
roof doesn't appear sturdy enough to support the dynamic loads generated by the air conditioner's 95 pounds, since there are only lateral ribs spaced at about 28" where I'd like to mount the A/C. All the posts I've found only reference cutting a hole in the roof and bolting down the A/C--I couldn't find any references to reinforcing the roof's structure beyond placing wood blocks between the inner and outer roof panels to prevent them from squeezing together when the mounting bolts are tightened. It seems that spanning between the lateral ribs with a steel frame would be appropriate, but I can't see how to attach that frame to the ribs without removing the sheet metal from the interior roof. If nothing else works, I could modify the emergency exit hatch hole, but I'd like to leave that intact for another use.
Any advice from those who have done this before (or links to threads explaining the process) would be greatly appreciated.
Happy Trails!
Happy Trails!
