So I am reusing the old door but connecting it together to make a single opener and moving my door and steps midship. I am not using the original step box. My interior steps will go down to the upper edge of the skirt, and then I have the lippert 3 step electric stairs for the rest of the way to the ground. I will be mounting the extending steps under and inside the first step body of the interior steps.
Here is a model of what I am planning on doing with 1x1" square tubing, I feel like this is way overkill, but wondering where I can make some changes or maybe use angle instead of square tubing.
The top short step should put me flush with my floor which has 4" insulation and3/4" osb on it.
The frame for the door I think Will be made out of 3x1 rectangular tubing. Metal shop does not have 3x1.5 at 14guage. I think I would need to jump up to 1/8" to get 3 or 4x1.5. Which May be wise for extra strength, but just also seems like quite a bit overkill.
Plan is to bolt the rear of steps to the frame and weld the foward part to the chair rail / existing structural parts at the wall. Use 1/2" angle to create my door jams along with piano hinge on the forward side. Outside of the box(closest to the wheel) will be reinforced With some thicker metal plate to protect in event of blow out, again may be unnecessary. The new door frame would also be tied into the nearest had channels horizontally.
Just wanted to get peoples thoughts here as this part of my build hopefully will start happening in the next few weeks.
Cheers,
M
Cheers,
M
