jjaj823
Hi all!
I find myself with a fairly nice problem for a change. I recently purchased 32 - 320 Ah LifePo4 battery cells. Which gives me 24,576 Wh of usable capacity, once adjusted for battery longevity.
My current battery bank is 32 - 120 Ah cells, for a capacity of 10,368 Wh.
IIRC, you shouldn't mix capacities in your system...which means I have to figure out what to do with the current 10k wh of capacity I have now.
My current setup is split phase 240 via a pair of 3k inverters. The 240v is for my dual zone mini split. Otherwise, I don't have any 240v loads, so I'm just using it to split up my kitchen stuff so I can run a couple of kitchen gizmos (conduction burner, microwave, oven, etc.) at the same time.
Anyone have any ideas on how I can set this up so that I don't "waste" the batteries I already have? They're still relatively new with less than 300 cycles on 3 of them and under 500 on the other (I messed up the cabling, so one was getting drained faster than the others).
This is certainly a nice problem to have, so any ideas are welcome!
:Thanx:
JB
:Thanx:
JB
