Mural Art Painting on a School Bus - QUESTIONS!
eborro
Feb 23, 2023
1
Atlanta
So, I'm a muralist with experience painting interior and exterior murals on surfaces like walls, bricks and such. I work with a co-muralist and we've recently been contacted by a friend who has a full sized skoolie that she would like us to paint with a custom design that we create. We're aiming to do our due-diligence by researching and preparing for this specific surface type, so of course I wanted to get the input from this awesome community on recommendations. The bus has already been formerly prepped and primed professionally by an automotive paint company, probably a year or so ago. So its entire surface area is a dull-ish white (not glossy). We've tried to gather the specific paint type that it was painted with, and did an alcohol test which didn't bring up any paint so our guess is likely some form of oil/enamel automotive primer.
Now we're aiming to pin down what paint type we use. The tricky bit I'm curious about is that pretty much all online bus painting comments and videos and such are from those who really painted their buses one or two solid colors. Much harder to find those painting art on the exterior and their process. We wouldn't be using a big sprayer for the paint considering it will be broken up into various smaller areas of shape and design. We also need color variety to pick/have the paint tinted pretty much exactly the colors we need. And at the end of the day, we want the paint to stand the test of the elements and time. What's recommended? I'm seeing a lot of emphatic no's regarding exterior latex paint (even high-quality?). We do also use Montana spray paint, so we've considered that as our primary option, perhaps with a clear coat. Is there a recommended non-latex rollable paint? I've seen a mix of recommendations like SW All surface enamel, exterior latex enamels, Sherwin Williams Industrial Water based Enamel... Ideally water based or just going with spray paint is what we're leaning towards versus the oil based route, but we want to make an educated decision post continuing the convo with SW and an automotive paint co as well.
We will be prepping the surface further prior to painting or arrange for them to prep it. Right now the plan would be to scuff up a little bit by sanding, wash down with water and degreaser, let it all dry out some days, then wipe down with clean cloth immediately prior to painting.
Any thoughts would be great!
Hi Guys, I’m a graffiti writer/ muralist out of Wilmington NC, and I am CURRENTLY painting (well, attempting to) a full size school bus that’s being turned into a mobile video game Bus for Kids. Before I started I was basically in just about the exact same boat as you guys seemed to be from what I read and the questions you were asking. I had a lot of the very same questions actually and still could use some advice myself on efficiency, paint types, and general process/ best way to get clean linework on the CRAZILY nooked and crannied/ extremely un-leveled bus surface that I’m slowly working my way through (VERY slowly).
Long story short, I can tell you the things that I’ve tried so far so basically you can see what NOT to do lol. Joking not joking, most of the things I’ve tried have just been what my normal processes have been when prepping and planning for big wall murals I’m going to paint, but prepping for putting artwork on a vehicle (esp a gigantic school bus) is MUCH more involved as you probably already know by now.. but Anyways, i began by heat gun removal of all non painted on decals around the whole bus. Don’t try just sanding them off, (it still shows right thru 3 coats of primer😒)
Just heatgun them a few seconds and semi-easily they’ll peel right off with a little effort.. next… the sanding…. Uhg the frikkin SANDING!! 🤯 and PS I’ve had 0 help from anyone on this it has been JUST me from the getgo) but I used a dewalt cordless orbital sander, using 120 grit on JUST the rougher areas around the bus then 220 for the rest and hand sanded any spots that couldn’t be reached by the sander. After about 6 long hours, the first sand was finished. Next, a full on scrub and pressure wash the whole bus, let dry overnight and wipe with a clean micro cloth lastly to remove any left over oils or residues. Next, Prime time… this is where I searched the internet for DAYS to try to find the best, most cost efficient, time efficient, compatibility with acrylic aerosol paint , method of application, ETC. THERE WERE SO MANY DIFFERENT ANSWERS!!! That fact PLUS the fact that my hometown. Lowe’s didn’t have enough cans of the color of rustoleum protective enamel roll on gallon paint I chose that I was going to use, OR enough cans of the same color tarp cans I was gonna go with secondly, so (and DONT go this route cuz it is long and winding, but I got frustrated and already knew that. Kilz 3 was an excellent primer for pourous exterior walls with so why wouldn’t it work on a bus? So I rolled it on using a 6” foam roller being VERY careful to not “press” the roller down too hard on the surface near where any 2 metal sheets of the bus met and were attatched with rivets because the drips from this will drive you insane and it’s literally like they never stop dripping no matter what you do, which if you don’t spot them right away to wipe, makes the next sanding sessions a nightmare . I did the sand btwn each layer of primer process a total of 4 times through and finally got so tired of sanding and priming that I stopped but honestly it probly wouldn’t have hurt to do it like 6 times in total depending on the opaqueness of the primer you chose..I know I could have (and probly SHOULD have in retrospect) used an air sprayer to prime with, but I did t want to have to stop a lot to clean it or risk having the “heaviness” of the sprayer cause a lot of hard to fix dripping, I knew with a small foam roller and just applying the primer by lightly rolling it out nice and smooth and evenly as possible seemed to be like the way to go, but if I had to do it again I would probly at least see how the sprayer would do Instead. Having done it this way, I can safely give this advice… if your going to roll on the primer for smoothness… I recommend just doing the rolling onto the long flat surfaces like the sides below the windows, the roof center, the hood, the back door only and don’t even worry about taking the time it takes (which is a TON) to try to get your roller into the nooks crannies and crevices of the bus and just come back with a can of white spray paint (weather using good paint like your Montana Cans which are a bit pricier or a can of white matte rusto, to hit those areas with. The all sand about the same way and All hold future sprayed on paint on top of it pretty well if allowed to adequately dry first. The sanding and priming process(in my experience so far with this bus I’m painting ) is probly the most important thing to make sure that’s done RIGHT no matter how long it takes though, cuz if it’s not, you’ll just end up spending all that time u “saved” fixing things caused by it NOT being done right towards the end. In total I spent 13 days JUST prepping this bus before I even laid the first BIT of any artwork down.. 😳😑 Just realized I forgot about all the tape masking and reflector covering/removal taping mirrors/lights (luckily NOT the windows though cuz I was going to be painting the windows from the outside cuz being that it was a video game bus the windows and back door were all blacked out from the inside). Obviously Do all this process before the initial first sanding.
Finally, after a full days time to dry and cure/ and all spot sanding and wiping down was done, finally.. it was time to start laying in some outlines for the artwork. Which leads it up to about where I’m at now currently and where I’m having a TON of questions arise on just what the best way to go about certain processes that yield timely and high quality results at the same time. Being that I normally work on flat, level, uncorrugated wall surfaces, the variations in the bus surfaces was REALLY difficult for me to not only achieve the level of cleanliness in my linework as I am used to, but even just making an even straight line of tape if it was the least bit at a diagonal angle across a window or series of rivers, has been frikkin IMPOSSIBLE it seems. And what is NORMALLY my “bread and butter” - my passion in life- spraying graffiti style letters… which I can usually do with my eyes closed and one hand tied behind my back, having to paint them across these bus windows, CLEANLY???! Is Another what seems like impossibility. So I am at a stand still at the moment on this cuz I am racking my brain trying to figure out what the next BEST steps are with this bus job that aren’t going to make me eventually have to backtrack and redo stuff I’ve already done, so I can maybe finish sometime this decade and get PAID, while at the same time making it look super dope and clean for my client and his customers. So I know this reply is EXTRA long-winded, and you were more so looking for some answers instead of more questions, but from one Aerosol Fanatic to another, if YOU guys could throw ME any knowledge you come across along YOUR journey painting your Bus that you’d be willing to share to help me out with anything I talked bout in this huge rant, id be MOST APPRICIATIVE !! Thanks and best of luck!!
Sincerely,
Manix✌️🎨
Long story short, I can tell you the things that I’ve tried so far so basically you can see what NOT to do lol. Joking not joking, most of the things I’ve tried have just been what my normal processes have been when prepping and planning for big wall murals I’m going to paint, but prepping for putting artwork on a vehicle (esp a gigantic school bus) is MUCH more involved as you probably already know by now.. but Anyways, i began by heat gun removal of all non painted on decals around the whole bus. Don’t try just sanding them off, (it still shows right thru 3 coats of primer��)
Just heatgun them a few seconds and semi-easily they’ll peel right off with a little effort.. next… the sanding…. Uhg the frikkin SANDING!! �� and PS I’ve had 0 help from anyone on this it has been JUST me from the getgo) but I used a dewalt cordless orbital sander, using 120 grit on JUST the rougher areas around the bus then 220 for the rest and hand sanded any spots that couldn’t be reached by the sander. After about 6 long hours, the first sand was finished. Next, a full on scrub and pressure wash the whole bus, let dry overnight and wipe with a clean micro cloth lastly to remove any left over oils or residues. Next, Prime time… this is where I searched the internet for DAYS to try to find the best, most cost efficient, time efficient, compatibility with acrylic aerosol paint , method of application, ETC. THERE WERE SO MANY DIFFERENT ANSWERS!!! That fact PLUS the fact that my hometown. Lowe’s didn’t have enough cans of the color of rustoleum protective enamel roll on gallon paint I chose that I was going to use, OR enough cans of the same color tarp cans I was gonna go with secondly, so (and DONT go this route cuz it is long and winding, but I got frustrated and already knew that. Kilz 3 was an excellent primer for pourous exterior walls with so why wouldn’t it work on a bus? So I rolled it on using a 6” foam roller being VERY careful to not “press” the roller down too hard on the surface near where any 2 metal sheets of the bus met and were attatched with rivets because the drips from this will drive you insane and it’s literally like they never stop dripping no matter what you do, which if you don’t spot them right away to wipe, makes the next sanding sessions a nightmare . I did the sand btwn each layer of primer process a total of 4 times through and finally got so tired of sanding and priming that I stopped but honestly it probly wouldn’t have hurt to do it like 6 times in total depending on the opaqueness of the primer you chose..I know I could have (and probly SHOULD have in retrospect) used an air sprayer to prime with, but I did t want to have to stop a lot to clean it or risk having the “heaviness” of the sprayer cause a lot of hard to fix dripping, I knew with a small foam roller and just applying the primer by lightly rolling it out nice and smooth and evenly as possible seemed to be like the way to go, but if I had to do it again I would probly at least see how the sprayer would do Instead. Having done it this way, I can safely give this advice… if your going to roll on the primer for smoothness… I recommend just doing the rolling onto the long flat surfaces like the sides below the windows, the roof center, the hood, the back door only and don’t even worry about taking the time it takes (which is a TON) to try to get your roller into the nooks crannies and crevices of the bus and just come back with a can of white spray paint (weather using good paint like your Montana Cans which are a bit pricier or a can of white matte rusto, to hit those areas with. The all sand about the same way and All hold future sprayed on paint on top of it pretty well if allowed to adequately dry first. The sanding and priming process(in my experience so far with this bus I’m painting ) is probly the most important thing to make sure that’s done RIGHT no matter how long it takes though, cuz if it’s not, you’ll just end up spending all that time u “saved” fixing things caused by it NOT being done right towards the end. In total I spent 13 days JUST prepping this bus before I even laid the first BIT of any artwork down.. ���� Just realized I forgot about all the tape masking and reflector covering/removal taping mirrors/lights (luckily NOT the windows though cuz I was going to be painting the windows from the outside cuz being that it was a video game bus the windows and back door were all blacked out from the inside). Obviously Do all this process before the initial first sanding.
Sincerely,
Manix✌️��
Not sure you'll be able to delete those duplicate posts-just let them be I suppose.
Regarding painting a bus/uneven surfaces, the first thought that came to my mind was go to your local railyard and see out the taggers painted the railcars. There's some fantastic work on those vehicles, and the corrugation and rivets and such don't seem to be an impediment to them.
Granted, you may have a different idea of how to decorate and graffiti style may not be what you want.
The other thought is if you decorate the outside of the bus it will be an attraction for taggers, so you may want to put a graffiti-proof coating on the finished job so you're not disappointed after leaving the bus somewhere overnight.
Have you considered something short of full-body painting? Maybe smaller panels are sufficient, and the detailing can be added on the inside, like the ceiling...
I know some people who's garage door faces into an alley. It kept getting graffitied and they kept painting it white. Eventually, some friends of theirs decided to paint a mural on it for them. Nothing fancy or professional, but a decent mountain scene. It's been 10 years and while the neighbor's garages still occasionally get tagged, that mural hasn't been touched. Artistic respect maybe??
I have little to offer in answer to the OPs question, other than I've used industrial alkyd enamels from both Sherwin Williams and Benjamin Moore. You can get paint from either place custom tinted. In my amateur opinion, these paints are very similar in application and performance to Rust-Oleum, but worth the extra cost if you need a specific color. They'll get chalky over a few years, but otherwise should work fine for a bus. I've read good things about the industrial acrylic enamels from both companies and wouldn't hesitate to try that out next time I need to paint something. They're probably not going to last like automotive paint, but they're infinitely better than latex house paint.
Hey Manix, I saw your post and figured I’d throw in my two cents. I’ve been writing since 2007- walls, trains, and any kind of random surface that feels like the perfect spot, with respect.
When spray painting an uneven surface, as you probably know, angles are everything. You’re probably gonna have to view every side of those rivets (being circular) and if I were you I’d mentally cut it in half, making sure you get coverage of one full half (angling the can off center) to cover the entire side, and do that on both sides of the rivets. Hopefully with that technique you won’t have to come from the top or bottom also. I assume you’re using specialty caps so that helps, but I’d recommend low pressure cans, specifically the original Montana (MTN aka “Spanish Montana”). Their 94 line is perfect for low pressure and the stock caps they come with make about 1-2” size lines with decent flair. I won’t get into the politics of German Montana but in my humble opinion Spanish is the only one I’ll use. Spray Planet is the company that ships out of the US, so you can order online if you want and get it delivered.
I just ordered a couple cases for my bus and I’ll be using your tips on priming!! Thanks for that!
Best of luck
Maria
No answers. Just an example.
ive seen murals on more than one bus and my impression is I LOVE IT!!!
the sky is the limit on ideas.. one family had taken the "uhaul" concept to a new level.. on uhauls they often list a place with a small pic of the map or a landmark.. this family airbrushed a place name and a landmark or such ion a small area on their bus each time they went somewhere.. there were dozens of places.. I gazed at that bus for an hour or more looking at all ther places they had travelled.. and a good portion of the bus was still just white.. waiting to be filled in...
