Winter has finally arrived. Temps never climbed out of the 20's yesterday and we have snow.
Took just over 2,200 pounds of scrap off of the truck, including the rear axle, about 12 foot of frame, the cab, ect. Scrap steel is going for $100/ton right now, so that was a nice bonus. She should weigh about 2,000 pounds without passengers now.
Well I didn't get any photos, but last nite we set sail on the trucks maiden voyage....actually we just started her up and drove around the yard for a few minutes. Mostly so i could move her out of my fathers barn and to test our new steel 10 gallon fuel cell.
The project isn't quite finished, but everything works. The rear wheels drive the correct direction, the rear steer works although a little slow. I didn't have any power steering fluid laying around and tried to substitute hydraulic fluid instead....apparently those two materials have different properties at 20 degrees F. With the tires on the drivers side in the air and the slack taken out of the system, i marked the front and rear tires with chalk then spun the rear tire wich in turn spun the front tire so i could check how accurate my gear ratios are. After about 6 revolutions the front and rear tires are still nearly perfectly inline. I'm very happy about that.
Still need to build the rollbar, move the radiator, paint, build a few guards for the spinny parts, add seatbelts, ect ect ect
My passenger is the guy who helped me build the truck. When he chooses to ride in the passenger seat that is an example of informed consent. Driving/riding in the truck isn't a guaranteed death sentence. Beides the increased chance of rollover, what makes this truck so dangerous? iamadumbass, what makes you qualified to be an armchair critique? Between the 2 of us, we have years of schooling and real world expierence when it comes to fabricating, mechanical, electrical, and metal work. We also have nearly 20 years combined fire/ems service which gives us a good perspective on safety.
above is a diagram of two exact axles, each with the yoke pointing opposite directions. On the left is an example of how the axle is oriented in my truck. I think it is easiest to understand if you try to orient yourself looking at each shaft/axle individually. In the photo on the right the yoke is pointed away from you. If you were to orient yourself so the yoke from the axle (in the photo on the right) were pointing toward you it would in fact be spinning conter-clock-wise. IF anyone were to doubt that the tires would in fact spin the opposite direction when the yoke is pointed to the front instead of hte back, take an axle and try it yourself. If you do, please shoot a video and post it for all to see.
