CMORGANSKOOL
Since you already replaced the thermostat, coolant, and cap, the other important items in the cooling system to check are radiator, fan, and water pump.
The point of a radiator is to create an large surface over which heat is exchanged from the coolant to the outside air. That surface needs to be clean on the air side as well as the coolant side to do the job. On the outside look for bugs, dirt, and grime built up between the fins. You can address that with a general purpose degreaser or a special radiator fin cleaner solution and gentle water pressure. (Do not hit the delicate fins with a pressure washer).
To assess the scale buildup on the inside surface of the radiator you need to drain the coolant and take one of the hoses off the radiator. It should not look like a coral reef inside. If it does, you can flush with a scale remover but I would just replace the radiator.
If you have an electric radiator fan, verify that it kicks in. On an engine driven fan you will have a viscous clutch that I would just replace at the mileage of your vehicle.
While you are troubleshooting the cooling system, check the turbo charging system for leaks. Low boost pressure leads to over-fueling and overheating. On the exhaust side, look for tell-tale soot and on the intake side check hoses for cracks and clamps for tightness.
What about the water pump? They typically leak well before the impeller is so eroded that it will affect cooling. I would only take the pump off if everything else mentioned failed to rectify the problem.
I had a similar issue when my water pump went, but a water pump should spew fluid through the weep hole when it dies. If no weep, I would assume coolant system issue too, fan, filter, radiator blockage.
