My entire interior framing will be metal.
So will my cabinets, cupboards, closets, ect.
There will be no change is size from moisture/climate, no rot, bugs, falling apart from vibration, ect.
I can't wait to get to that stage of the build.
Nat
Will you be using steel studs like the fellow in the video, or normal steel-yard steel?
I, personally, wouldn't use the steel studs for anything inside of a bus. As was mentioned, they take up a lot of space. Also, they seem rather flimsy unless properly sandwiched between sheets of plywood or steel. I like building with proper steel, though, such as angle iron and square tubing, but I typically use wood unless I want the extra strength.
