Need help 2002 thomas hdx
Shibunn
Nov 23, 2017
5
I have a 2002 thomas hdx saf-t-liner and need service manual o wiring diagrams I got ride of some wires and now my defrost doesn't work and would like to get some wiring diagrams, I haven't been able to find them i even called a dealer and they send me some diagrams but were not the right ones anyone with acces to the thomas page?
I had similar prob on my 01 saf t liner. It was a complex problem to solve. Post a pic of what you are looking at. My labels were not correct, but after long enough with a volt meter I traced the whole thing out and it is working again.
This is what I'm looking at I want to get ride of all those wires cuz the door on the other side is leaking and dont know if I need all those wires
You can do this all for me outside if you want.
Those bolts at the top left and right of the panel come out and then the whole panel folds down and out so you can access the backside from the outside.
It’s pretty hard to tell from what you’ve got going on but I can tell you for sure if your bus is like mine, that one of those wiring harnesses on the backside of the middle panel is supposed to go up to your drivers heat and defrost
Three wires if I remember right. Fed by a series of fuses and relays.
We have an 04 Saf T Liner, schematic on the back of my panel door. It does include the defrost.
Have it here, maybe the same?
https://drive.google.com/open?id=0B3HKBlMfEQwgNzJOaXZsNkctNkhlZkNzY3YzSy15Q3FadUZZ
In the pic I can see the diagram on the door, is that's not enough Thomas sent a link to my mechanic to download from their archives. Maybe get a mechanic to make a call for you
I have the PDF for 98-99 if you want, don't know if it'd be the same
