BlueBirdSong13
- Joined
- Aug 20, 2019
- Posts
- 4
Just what the title says I have tried everything and the bus still drives and everything just an extremely loud buzz the entire way
It happened after I eradicated some wasps out of the stop sign holeAs ECCB above, but before diconnecting the buzzer I would make sure I understood exactly why it's buzzing.
It seems a little strange to me that a 2002 bus will still start with buzzers going off. My bus starts with the buzzers going off, but it's a 1995 and has no computer chips
My bus only has one buzzer in the driver's area. That one works for everything, except low air which has it's own warning system with intermittent beeping and flashing lights on the instrument panel. There are also buzzers on each emergency door and hatch that only go off when it is that particular door or hatch that is not properly latched.
The stop sign thingie on my bus was gone when I got it, so I have not paid much attention to it, but it must have originally had a sending unit to tell the driver when it was extended. So in your case I would find that sending unit and disable or remove it.
