Ninjakitty
Well, once it either starts raining in the bus or forming icicles, it will be a major issue.I'm just not seeing that as a major issue.
I don't think fire will be an issue with the thickness of your ceiling wood.
This may be dumb lol but if we get a real thin sheet of wood for the ceiling and put it directly to the ribs, is there any concern with fire or anything? Is there a certain width or layering other then insulation that should be in there to be safe? I know they get hot and with it being such a thin layer, I don't know if that's bad. Granted, the metal is thin and much hotter, I am trying to decide on the most efficient wood cieling.
Speaking as a 5'8 person with a 5'10 partner who isn't doing a roof raise, we still need to consider the thickness of our floors and whatnot. We're putting down a "floating" subfloor consisting of 1/2" foam board and 1/4" plywood. The foam board should have enough compressive strength to handle being walked on. I also built a sunken shower pan and frame to support it, which sinks the shower 8" into the floor and leaves plenty of headroom for us to shower comfortably.
And I know you said that you could not do a full roof raise, but could you possibly do a partial roof raise?
Maybe only lift the area you walk around in and don't lift above the bed where you sleep or the driver's area where you spend little time standing. Or, only lift the roof in the aisle area because there's little standing to do there (would probably look weird though).
In your situation I would probably still raise the roof. If you plan to live in it full time for a long time, I think saving your partner's back would be worth it. I don't think stooping all the time would be healthy.
I use my interior ceiling panels I took down to make patches and fill deleted windows, and will be using it to skin the shower pan once it's fully installed. You could do the same to fill in your bus skin post roof raise.
My father cut some tops off of some buses to make watermelon buses and they're just laying around. You could probably come over and harvest some sheet metal and structural ribs if you ended up going that route. As for a welder, you may be able to find someone to help on here or in your circle of friends. I can weld and would be willing to help myself, but with a full schedule of classes this semester I couldn't do anything until January.
EastCoastCB is a very helpful guy with roof raise experience. Maybe he'd be willing to lend a hand.
Thank you guys. If any of you are in Florida feel free to message me, I'd love to know some other Skoolies in the area.
So far, after being out the a while last night, I think we are going to extend the space where the roof emergency exits are to double the size on each one. Then get a customs skylight type thing. That way he has a lot.more head room in those places. Again, just an idea we thought of. So far it seems the most doable.
We are going to keep the original foot panels. Just going to wash them up real good, put in New insulation, and flatter screws.
Has anyone used Cellulose blown in insulation? Seems to be a healthy and efficient option.
In regard to the floors - We also found this stuff at Lowe's that is suppose to be both a vapor barrier and slight insulation. I'm kinda torn because I would like a thicker insulation, but my partner (and the people at Lowes) are trying to save the space and thinks that the one we found will work ok, along with our subfloor.
https://m.lowes.com/pd/FloorComfort-100-sq-ft-Premium-1-5mm-Flooring-Underlayment/1000195249
That's the stuff. Based of its description and what I've read it seems great but I'm worried it won't be enough.
We aren't going to be in freezing temps often. We will likely chase better weather... So Idk. What do you guys think?
Cellulose is a poor choice. Buses sweat like humans inside and its best to got non-organic for insulation.
How different is it from "cotton candy" type insulation? We don't wanna do spray foam, so our options are the cellulose, cotton candy, or foam board, but we have heard foam board in the roof can be difficult to fit and can lead to moisture issues as well.
Just seems so impractical and probably can't be done esthetically pleasing.
Why don't you give it a shot and post your results here?
What is he talking about insulating ontop of the roof? Makes no since.
