Sprout.sprocket
I’m pretty flustered with this build actually. Lost most of winter to SNOW (does not happen in nz where I was, now I am in Ontario, Canada.
Have all wall panels out, floor ply mostly out but will need to remove driver’s seat. Trying to put that one off so I can get the multiplex removed which means driveable.
Paid a bit for this one, more than I would have liked, but wanted a midbus without leaving Ontario. Looking for panel minded advice in regards to wheel well rust - mainly the wall cavity. The water has seeped in the windows for years and sat in the walls. Can see the rust line on the exterior. I have no issue in treating rust after grinding and cleaning, as well as priming, my issue is more how far I take down the wheel well corners - there’s even spray foam in the corners there. I feel like I’ll be cutting it all out somehow…
Anyway I don’t want to have a million pics everywhere as I’m too tech useless so they are all on sprout.sprocket /Instagram.
My learning curve for this build is chassis access - in nz instead of a steel plate it has a thinner I beam sub chassis with diesel heater channels (giant hunks of steel that cost me a lot of grinder blades and dust) meaning I could both access and clean up the chassis. I don’t have that luxury with this build but I do have ok access being a smaller female bodied frame. And I’m paneling over one side of windows, so going to deal with steel and window deletes too.
The most hectic thing to happen so far is I lost my multi osc bolt, before actually using the tool. Almost ready to use it and uhhh have to clean the house and hope it turns up… for some reason Milwaukee don’t sell spares for them, just angle grinder washers and flanges. Harrumph.
