Crisco-SKO
- Joined
- May 9, 2011
- Posts
- 14
Hi! I just picked up a 2003 Ford E450 17 passenger van. I think people call it a transit bus? It has the hydraulic handicap lift on the side.
Currently I bought it to move across the country with, and plan on converting it to a full on board WVO system and basic motor home amenities.
I have quite a bit of experience working on cars and 1 ton trucks, but this thing is pretty new to me. The wiring added by the coach company is very extensive! The spot where the passenger air bag would be is full of circuit breakers, relays etc. And they are all controlled by a master body disconnect switch by the driver.
Has anyone had any luck getting a wiring diagram for these buses? I want to make the entire rig a little less idiot proof and less redundant. IE easier to trouble shoot.
For instance the rear Carrier A/C works great, as does the heater, but they only work when the master body disconnect switch is on. Shouldnt the heat and A/C work all the time?
The next question is batteries.
I read on here quite a bit, and think I want to go with 2 8D batteries under the frame and a regular starting battery under the hood. It already has a 2 battery system. How are these typically done on these? Both in parallel? Does one run the A/C like some threads said? I didn't see a battery isolator under the hood.
Since I plan on running WVO I want to make sure I have the cranking power needed if I run into a problem and also to run 12v heaters as a backup.
