pete c-SKO
- Joined
- Feb 1, 2007
- Posts
- 263
Great board you guys have. I don't yet own a bus, but I did stay at a holiday....uhh, never mind.
I have been giving the thought of joining the skoolie owner ranks for awhile. Places like this and jake vonslatt's outstanding bus site have really lit the fire.
BTW, jake, I am just a few hours down the road in CT and I hereby volunteer my meager skills for any free labor you may need. I would really like to check out that bus of your's. After reading your board I am determined to eventually buy a bus, learn to weld and move to a town that still has a dump. Your dump scavenging talents have made you my hero. I used to live in such a town where I generally came back from the dump with more than I brought. Now, I am in a crappy town with no such priviledge. I am limited to whatever curbside scavenging I can manage.
I do have a few questions/ideas I'd like to run by you folks.
First off, is mileage or should I say lack thereof. From my reading here, it seems that 10-12 mpg on diesel is about the limit. Am I correct? If so, that sux.
I just became an RV owner myself. Well, you guys might consider an '86 22 ft toyota sunrader more of a toad than an RV, but, it will house 4 rather cozily. Also, it will get 18 mpg on cheaper than diesel regular gas, if you keep it below 60. And trust me, keeping a 22 ft 22RE powered toyhouse below 60 is really easy to do.
I have a conversion idea that would result in a decent sized heavy duty RV. It is a box truck. I once rented a 4 banger Isuzu diesel with a 20 ft box. It drove very nicely, and seemed to get somewhere in the high teens for mileage, although I didn't have it long enough to really get a good idea about mileage. The biggest challenge I see in doing it is figuring out a box to cab portal. Those box trucks have the cab that flips up for engine access. I have an idea that you could make an opening between the two with a flange on the box section and a mating flange on the box part that would overlap it. Another nice thing is, they all come with hardwood oak floors with nary a rusted to the floor seat to be found.
Another idea I am thinking about inflicting on my new sunrader is a grey water recycling system. Basically, you would pump the grey water to a vertically mounted length of 4 inch ABS pipe. This pipe would be fitted with screw on caps at either end for easy cleaning. The pipe would be filled with a fairly fine sand. I was also considering using DE or deciduous earth. This stuff is used in pool filtration and filters out damn near anything. The water would gravity feed it's way through the sand/DE to a seperate tank. This tank would be the shower water supply tank.
Obviously this system would require ample amounts of chlorox to keep from becoming a disentery nightmare. It would also be dependent on the users seeing to it that fluids other than shower water not find it's way into the mix. Peeing in the shower would be highly discouraged.
I would install various Ts to provide for traditional use when hooked up to shore water.
As for black water, I'd do away with it completely and use some sort of composting system. I even have the idea of putting some of that free exhaust heat to work in this capacity, although the possibility that crap can burn would probably discourage this idea.
I realize that you folks in the bus game probably wouldn't go to the trouble of shedding weight as we toyhousers will, but, the thought of not having to carry so damn much water around might free up weight for, I dunno, a slate pool table or something. It might make your stops to offload grey/black tanks a lot less frequent.
Any tips, ideas, comments, suggestions, ridiculling would be greatly appreciated.
Pete
Pete
Just let me know when you're ready to part with that full floating 8 inch rear axle...
