CMORGANSKOOL
Time to pop a fitting off and see if you have air flow.
Hard for me to tell from the pic, but how "new" would you say it is? One of the bolts looks like it hasn't been turned in ages. Since you already have a replacement, and yours looks easy to access, why not go ahead and change it out anyway?
It might also be a good idea to make sure the air inlet lines are not obstructed - there may be a filter somewhere.
Ok, with the engine running, I pulled both lines off of the governor and neither was moving any air. What does that mean?
Inlet into the governor?
It looks very new. Within a year
In driving 400,000 miles across 4 years with gear-driven compressors, I have had one fail, and the truck in question was a worn-out POS.my bus is a belt driven air compressor.
can put my hands on every piece of it without any issues.
air brakes lock at anything 60 or below.
dont have any airbags yet but will add an extra air tank with check and bleeder valves when i add them
dont like the idea of a gear driven compressor behind the timing chain cover?
what a pain in the ass that would be!
i will stick with my belt driven one
Ok, new governor. No different. So, how do I check the compressor? I dont hear any leaks.
Could be pumping air, but not pressurizing. Maybe blowing back out the compressor?Man, I wish it was that easy.
So I ran it and I couldn't hear or feel any leaks.
Oddly, I can hear one of the tanks (there are 2, maybe 5 gallon tanks under the drivers area) filling but it doesnt hold any air. Once I kill the engine, I can hear it slowly empty. Its not leaking itself but its leaking some down stream? There has to be a mile of airline in this thing. Now, keep in mind that according to the guage, it builds 0 air pressure. Maybe its the compressor? I have no idea...
Bad compressor or one **** of a leak between the tank and the compressor.Should I just replace the compressor? Is 0 pressure a sign of a compressor failure?
