The Chief
Hey guys, I need help. I have searched and searched in an effort to figure this out on my own buy my last resort is to ask for help so here's my first post.
I have a 2001 International/Amtran bus. We use it for tailgating and staying warm between hockey games for our kids. Recently, the entire noise kill circuit started blowing a fuse killing all of the fans which completely defeats the purpose of the bus.
I have replaced the solenoid/contactor that controls the noise kill circuit. I have identified almost all of the fuses in the fuse block and matched them back to the diagram on the inside of the door. The fuse that keeps blowing is a 10 amp fuse that I can only identify as "Spare" on the diagram. The fuse blows when the noise kill circuit is on and when it's off. To this point, it only blows when the bus is in motion which leads me to believe there is a wiring bouncing around somewhere grounding out, blowing the fuse.
I have recently replaced the flashing lights with LED's and thought maybe one of the wires I unplugged was shorting out. I have since taped off every loose wire and removed the controller that handled the flashing lights.
I traced the little gray wire from the contactor and it goes straight to the switch at the helm, doesn't go through the fuse block to the "spare" fuse or anything.
I'm at a loss here. What could I have changed on that circuit that is blowing an obviously not "spare" fuse.
Please let me know if anyone else has experienced this and what you found to be the issue. If you need pics or further info, please let me know how I can help you, help me!
Thanks all,
Jeff
Thanks all,
Jeff
