browningcrew24
- Joined
- Oct 12, 2018
- Posts
- 1
My family and I are currently in progress on our '79 International Harvester skoolie build. After a lot of "research" and reading I have decided I don't want to deal with a battery bank/inverter set up right now. The reason being is I will always be right next to shore power and have a generator for back up. The bus will be parked here for 98 percent of the time and only moved when off loading grey water tank and when the space is needed for events (thats when we will use the generator). Here is my question and I think it odd but I want some advice or at least thoughts. The shore power I can hook up to is a 20 amp GFCI plug but I will have 2 or more 20 amp circuits within 50' of the bus. I am wondering if it is possible/a good idea to have 2 - 20 amp circuits in the bus each with a plug for shore power on the outside plugged in with 2 different shore power 20 amp circuits. When not near the shore power I would replicate this using my 8000 watt generator that have and A and B 20 amp circuit breakers and plugs. Does this sound reasonable or doable? :Thanx:
