timbrass
My Odometer is not working.... any ideas on how to figure out the cause on a DT466e. I'm not sure which cable to check... if anyone has a photo that would be great!
Same here.. I'd truly be surprised if it is cable driven. It's probably easy enough to lift the cluster out and have a peek; a mechanical drive cable will be easy to identify once the back side of the assembly is visible. If indeed it does have a mechanical cable, then you can start troubleshooting whether the cable end turns, if not then trace it out to find the other end..Afraid I can't help much. If it truly is mechanical, typically the cable runs either from the transmission or the left front wheel. I'm still going to go with electronic in that new of a bus.
