JamieJackson
Last night I was moving the bus to a new location to work on it. It was about 30 minutes away, and 20 minutes into the drive there was white smoke coming from the engine bay.
I pulled over and turned it off and it looks like ATF fluid (reddish in color) is all over the left side of the engine bay. The transmission shifted fine and ran like it's always done, but the levels are low on the dip stick.
I noticed into the drive the power steering wasn't working, it was getting harder to turn if I won't moving forward at a decent rate.
Where I stopped at wasn't a safe place on the highway, so after it cooled down, I started it and drove it up the ramp/exit about 300 feet away and it shifted and drove and ran fine, but something is wrong, I just don't know what.
It was late and dark so I couldn't see much, although when I started it to move it off the highway, I started it from the engine compartment so check for busted hoses and oil being shot from anywhere and I saw nothing.
I am going back to the bus later today and check it out in the day light, but just wanted to see if anyone could direct me what I might be looking for.
It puzzles me that it looks like all the hydraulic pump and powering steering is on the right side of the engine, but the fluid was covering the panels and compartment of the left side. The two dip sticks, oil and transmission are on the left side, but I couldn't see them leaking of blowing off fluids when I started it to move it from the highway.
the entire engine compartment was clean except for where the red circle is on the image.
It has me puzzled... any help would be greatly appreciated.
