ism minerals
I found a god deal on a Onan generator that I will be adding to our Bus.
The bus is a 2001 thomas MVP RE. I was thinking about putting the generator on sliding rails and place in the front of the bus between the frame rails.
The question I have would be the fabrication of a front sliding section. and more specifically fabricating the front flat nose to move with the generator sliding try. Should be easy with some welding and rivets.
Has anyone seen this done on a skoolie?
. I will put it in the same spot, but not on slides; going to be a pain to remove or work on it if needed. Good part is most of the routine stuff is will be easy to get to.
