G Dub
I'd like to see a discussion on these relatively new valves that allow a one-way flow of fluid through the plumbing. It seems to me that in using these valves one could combine the grey and black water tanks into a single combo tank that holds both grey and black waste water.
When I think about the advantages of a single combo waste water tank, I see how solids would no longer be able to build up as they do in a black water tank. The water from the faucets and shower would work to break up the solid matter. This would mean fewer erroneous readings from the black water tank on your tank level meter.
I think this is a win-win. What do you think?
Please do NOT post about cat boxes (composting toilets). This post is about using water in the plumbing.
Thanks
Thanks
