Stu & Filo. T
Was it my eyes or after he removed the magnet and ran it up again there was more shaking than with the magnet installed. Watch the left edge of the tire.
Yeah it looked slightly out of balance after he removed the magnet, but that imbalance and the size of the centramatic weren't to scale compared to the size of the tire. The only thing that I have a problem with, and that nobody can seem to ever answer, is how many rpm does the tire have to be turning in order for it to be balanced? I'm just curious if it would even work at slower speeds.
Most commercial tires nowadays are balanced using poly beads internally. Don't heat up or damage the rubber and won't sling off like lead.
I'm thinking of using them too, do they use a different valve stem on them? did you do all your tires? have to replace my steers, drives are good so I wouldn't be balancing them (yet)I use Counteract beads, very pleased with them.
If I were going to even put half the amount of miles on the tires that they're rated for, I'd care what brand they were... But on average, how many miles a year does the average skoolie see?
On my scooter the difference between top brand and chinese is ten bucks. On My bus its a totally different story.
There is no solid, independent evidence that recapped tires are any more likely to fail than virgin tires. I'm actually finalizing lots of research and am close to doing a video, to share the results of the studies done on this issue...and on tire age. The best study was sponsored by NHTSA and done by the University of Michigan, analyzing tire debris...many tons of it. It's worth reading the report. Recapped tires are permitted, legally, in any position on our conversions. They are also allowed in any position on any commercial vehicle, including those carrying hazardous materials, with the sole exception of the front (steer) wheels of passenger buses. Personally, I don't find any compelling reason to avoid them. But each person needs to make that decision for themselves, of course, and I'm not trying to talk anyone into it...I just want to share the best available data.
Also on a scooter, a tire failure can cause you to die.
Less chance of that with 6 tires and 20,000 pounds of steel around you.
Nat
I recall reading at some point that the biggest cause of tread separation on heavy duty vehicles is improper inflation. Interesting to note that, even with something like heavy truck tires that are supposed to be maintained by 'professionals', lack of maintenance, i.e. failing to do one's job, might be the most significant factor in catastrophic failures. Reading this got me to thinking that, before I hit the road I'll develop a pre-departure checklist. So far I have 4 items on it:
Check tire pressure.
Fresh cup of coffee in cup holder.
Empty bladder.
Snacks within reach.
Empty bladder.
thats a good start.
search pre trip checklist/inspection on here.
used to have a member named cheesewagon that was well versed in tractor trailer stuff and he had posted a pretrip checklist for us some years ago.
