chromaglow
Hey Everyone,
Fall is coming here in the PNW and that means rain so my idea is to get the bus sealed up nice and dry so I can keep working on it all fall and winter. It's been a minute since I posted but I have been busy taking out 1131 rivets by hand and raising the roof 27inches on The Heart of Gold.
I have some questions about what to do next. I have been so focused on getting the demo and roof raise heavy lifting done in the last 4 months I am not sure how to proceed in a way that will minimize duplicate work.
Here is my plan please tell me if this makes sense.
So the roof is raised (photos coming soon) all the metal sheets are tacked in.
1. Drill and re rivet metal sheets in place.
2. Wipe the oil from the sheets inside and out and paint with oil based primer to protect from rain
3. Use hanks 212 to seal all the sheet metal seams and blind rivets from the inside of the bus.
4. re-seal all existing ceiling seams with hanks 212 from the inside.
5. spray foam my roof and walls while the moisture level will allow proper curing
6. figure out my roof rack for solar panels and deck
6A. Clean and paint the roof
7. drill, mount, and seal all roof rack holes in the ceiling
8. Finalize where all holes need to be in the floor for toilet, water etc and cut them
9 Seal bolt holes in the floor
10 build subfloor
11. Frame walls and ceiling with wood and drill holes for propane, water adn electric
12 finish insulation of walls and ceiling
13 run water gas and electric in walls
Thoughts? What am I missing?
Time-saving ideas?
Just trying to make sure I don't have to undo or redo things unnecessarily
10 build subfloor
Time-saving ideas?
