lornaschinske
I've used the search function and still can't find what I'm looking for (I did not go thru all 86 pages). We have a BlueBird All American FE. Is the heat exchangers on a separate loop from the engine cooling system or does it intersect? On our Eagle the DD engine had a "preheat" loop thru the engine that was independent from the engine cooling system. Would the BB have a similar setup? We were told at the time of purchase our BB is supposed to have a DD in it. But I ran the VIN and it came back as a GM 8.2TA Gas (we fill up with diesel). I want to use the existing heat exchangers for heat and add a dedicated LP water heater into the loop to heat the coolant.
