Anomalous
If you have a conventional style bus with a significantly raised roof, would it be feasible to extend the roof out over the engine and put a bed in there?
I've noticed that conventional style buses are more common and often cheaper than the flat front ones, and I've read that the engine is a lot easier to work on (compared to flat nose front engine buses). However, the interior space is a lot more limited. Assuming that the roof is being raised a lot, say 2 feet, could we take a cue from the class C motorhomes and put a bed up over the driver and engine? It looks to me like you have at least 1 foot of space above the windshield before raising the roof, which would make for 3 feet of space with a 2-foot roof raise. 3 feet should be adequate for a loft bunk, right?
I guess the toughest part is that you'd have to build a frame extending over the engine. I'd think that this is no big deal for someone who is already raising the roof though. I'd also wonder if it makes it hard to see stoplights if you're near the front of the line.
Another thing to watch for is that there is sufficient clearance for the hood to swing open. I'm not sure how high the hood reaches while opening it. Does it need clearance any higher than the top of the windshield?
