upbeat
In reading the manual on my Fuller T-905 transmission I was sort of amazed to see that it can be rebuilt as an overdrive unit, which would change 5th gear from 1.00 to somewhere around 0.65.
I say somewhere around 0.65 because I have the M gear set, and while the M is listed, it is not listed in the table on overdrive ratios.
And amazed because that's what I love about nice, old, rebuildable, versatile machines.
Which brings me to the real question, what's the right transmission for my bus? Figure I'm optimizing for 1) fuel efficiency and 2) fun and easy to drive anywhere.
The truth is, the jump from 1st two second is about 1,000 RPM, which is too big in my opinion. Going up any kind of grade it's hard to get to second gear before the vehicle slows down too far.
The rest are 500 RPM apart, and she goes 62 mph at 2,000 rpm in fifth. If I rebuilt to an overdrive at 0.65 then I'd be down at 1250 RPM at 62 mph. But would she cruise at 62mph@1250RPM. Maybe because I'm nearly empty and not hauling a few thousand pounds of human flesh.
I'd been thinking a ten speed was the answer, but the real question is which ten speeds?
Another night I'll sit down and do the math. Here are the ratios for the deeply curious.
[/IMG]
Welcome your thoughts,
Adam
Adam
