- Joined
- Apr 18, 2010
- Posts
- 1,208
my t444e has a electric clutch, comes on at 211 shuts of 204, its a called a Horton clutch, if you have the same you can unplug it and run 12volts to 1 wire, and ground the other, you will here the magnet snap and hold against the fan pulley, you wont be able to turn the fan by hand, take the power off the and the fan will free will, this will let you know the fan clutch is ok, and you may have a bad sensor or broken wire, I have a broken wire somewhere in my harness, and have been using a switch to turn my fan on and off.
my bus is 1999 t444e
