Overwhelmed Newbie
CC08
May 5, 2019
4
We are picking up our 2004 Thomas saf-t-liner EF tomorrow! The first items on our to-do list are demo and painting exterior. I’ve searched the group for painting tips, but I’m still a little confused. Here are my questions:
1. Do we need to thin our paint (rustoleum)?
2. Will we need to sand the whole bus? If so, what grit?
3. Many talk about washing the paint with TSP or acetone or just dish soap. Is it necessary to use the chemicals or is dish soap enough?
4. We will need to remove the stop sign and arm. What do you use to patch the holes with?
5. Will any paper/newspaper work to tape up the windows and bumpers?
6. How many gallons did you need to cover your bus? Mine is 40 passenger.
Any other helpful info you want to share would be great! We are not painters so I’m a little nervous for this process.
There is much to do, but the journey of a thousand miles begins with a single step. Demo itself is several full days.
There is a thread you can read on painting
http://www.skoolie.net/forums/f10/painting-a-bus-524.html
Many advise this particularly if you are spraying
Yes-120/200?
Probably dish soap is fine
Bondo, silicon caulk, construction adhesive, epoxy, fiberglass etc
Sure
Several gallons?
this will save you hours and hours and hours masking your bus - I use the paper masking with the masking tool - - -
Yes-120/200?
Sure
Several gallons?
Thank you for your reply!
