Branden-SKO
Hi all,
I know I've seen a discussion on this but can't find it in the archives. I'm thinking about mounting two 33-gal blue food barrels over my rear wheel wells for fresh water storage. They'll sit on their sides, slightly tilted and in some type of padded wood cradles, then be attached with pipe hanger bands to the wall and floor (like how water heaters are wall-mounted for safety).
The barrels have one hole now, in the sealed lid, very near the edge (2" from it). The hole is about 3" and is threaded. I thought about using this as a drain hole, and looking for some PVC that would match the threads and be the drain pipe. At the top, then, I'd cut a hole and glue in a fill pipe that would go up through the countertop for filling.
Is there any reason you could see to reverse this? That is, custom-make the drain hole and use the threaded hole as a fill hole? If so, how do you reinforce the drain hole? Would you need to? It's 250 lbs of water, but I don't know how you get something into the tank as a backing--I'd like to have a threaded nut on each side, holding the pipe in place and reinforcing the plastic, but maybe this is unneccessary.
Thoughts?
Thanks,
Branden
Thoughts?
Thanks,
Branden
