Like the title reads! I have the 2, 12 volt sockets, in the dash that have no power to them any more. I plugged something in and it popped, so, I went ahead and plugged into the other one and popped it as well!
Now, I can't find the blown fuse. There is a fuse block under driver seat and, one in engine bay. All the fuses are good. ( I have re-checked them multiple times). I have moved the left and right kick panels out and there are no fuses there. I have looked as best I can with flashlight under drivers dash area as well, still no luck.
2003 chevy cut away express. If anyone out there has some helpful info, I sure could use some help to find what I think may be another fuse block somewhere.
Also, I can definitely see wiring from one of the sockets going right into a factory wire loom which has me believing that looking for a factory fuse block is where the blown fuse will be.
Thanks in advance!
Thanks in advance!
